Was on my way home and i started to smell coolant and the car was losing power. So i pull over and the engine started smoking. Step outside and notice there is coolant/antifreeze on the ground. Seems as if the top part of the radiator the big metal piece that is on top/connected to the radiator that the hose goes to and has the radiator cap on has a leak in it. Tried running that radiator stop leak(crappy i know) but i needed a way to get home. It didnt help. Eventually got it towed home.
Does anyone know a way i could fix the leak without replacing the whole radiator. Can i use a putty that hardens and put it around the leak or will that build up pressure and possibly blow the engine. Any suggestions would be good thank you. The engine is a 1.3 SOHC btw.
