Just painted the tailgate white on my F250 (it was 2-tone maroon & silver). I washed & degreased it, sanded it with 380 grit and sprayed it with 2 coats each of Primer Sealer and Duplicolor exact Match paint. I wet sanded it with 800 & 1000 grit between each primer and color coat. I then wet sanded it again with 1000 grit, applied one light coat of clear, and wet sanded it again. It feels smooth & looks "OK" but doesn't have any depth or much shine.
I realize it's a spray can job, but how do I get it to shine and have at least a little depth? Can I polish it out with mild rubbing compound? Steel Wool? Should I do that before adding another clear coat?
