Capri for under $500... should I get it or not?
  • Capri for under $500... should I get it or not?
    I have access to a capri in good running condition for under $500.
    Should I snag it? What all can I transfer to a festy? Engine, tranny, brakes...? Should I just keep it whole and flip it?
    Thirdman
    1992 White Festiva L - original owner
    1993 Green-ish Stinktiva™ L - totaled
    again.....lol. get it!! for 500 bux any car thats in good running condition is worth it!
      (thanks, I deleted the other thread as it was in the wrong forum...)
      Thirdman
        Get it and swap the festiva! Engine, trans, front brakes can be swapped over.
        -85' Nissan Sentra 5 spd.
          Yeah, great opportunity!
            is it the turbo one? if yes then its a deal!!! if no then its not really worth it IMO... unless there is alot of good usable parts on it....
            Mike, AKA the sasquatch
              Engine and tranny swap would still be a very noticeable upgrade. Scrap what's left and you can purchase the FMS mounts for the B6D. Axles are the useable with trans too I believe.
              -Donny
              -1992 Festiva GL
              B6D/E-series.
              -1991 GL
              BP/Broken E-Series. Working on G transmission.
              -2011 Mazdaspeed3
                Theres nothing better to have than an entire donor car. B6T swap with G25MR and all your axles/intermediate shaft... all the wiring... etc.
                Its well documented.
                I used the Xr2 front brakes on my festy. Theyre awesome. Theres even a bigger brake upgrade for them that gets rid of the rotor-behind-hub crap.
                Only problem is it keeps the stock bolt pattern and if you want a rear brake upgrade the only documented upgrade is aspire, which means different bolt pattern in the rear.
                Anyway, yeah, $500 for a running Xr2 is a steal.
                91GL BP/F3A with boost
                  for sure if its an xr2..
                  -Aspire brake swap COMPLETE!
                    alas, but it is not an xr2, and turns out to not be in as great of shape as I had been lead to believe...
                    Thirdman
                      So what fun thing(s) could be done with a $400 normally aspirated Capri with 165,000 miles on it?
                      Thirdman
                        Rebuild the NA B6T for turbo use. Part out the car.
                        Maybe use the F series trans.
                        Brake upgrade. Some base capris got the xr2 10.3 inch brakes. Some only have 9 inch brakes that are still a huge upgrade for a festy.
                          I am surprised that nobody mentioned the 24 Hours of Lemons....
                          Thirdman
