hi i'm looking to rebuild and than put my 88 motor into my 93 body..i know that the 88 is a corb and the 93 injectors...
88 motor into 93 body???
you can use the engine since it's b3.
but you'll either have to swap efi parts (heads, intake, etc) or swap the carb'd harness and a bunch of parts to change it over to carb'd
(edit>> or do you have to change over the head? maybe not, probably just the intake and any efi related parts)Last edited by walth; 07-28-2010, 07:55 AM.
1989 L - 247K miles Slick
Originally posted by batstiva View PostInternals are the same from 88-93.'93 Blue 5spd 230K(down for clutch and overall maintanence)
88-89 did have solid lifters, but won't hurt just have to adjust them some times. Only thing you need is the intake and the disty and block off the fuel pump spot. And the oil pressure sensors have different plug style so change that one as well. Then you be all set i just swapped a efi motor into a 88.
certainly glad you are here arrow, and that we can help. Tell your son we're thankful for his service and glad he sent you here for help.
