Ok, let me start off by saying that I am not a Chevy man. I prefer FORD'S. Anyways, my son sold his Ford Ranger and bought a 1998 Chevy Caviler. Well shortly after he brought it home it started to over heat, so I went to check it out. What I saw was a lot of rust in the overflow tank (no mixture between the oil or coolant). So we flushed the system and replaced the thermostat and radiator cap, but the car still overheats. I am 100% positive that the thermostat is in right, and the fan does come on. We spent about an hour lastnight trying to burp the system, but still seems to have air in the system.
I am thinking the water pump might be going out, but not positive. The car does make a sound like a bearing or something is about to go out, but I thought it might be the a/c compressor, because the air doesnt work(another issue I will worry about later).
The car will run fine with the radiator cap off and idleing, but as soon as we give it some gas it starts to come out of the resovior, and when we put the cap on it starts to run hot. The fan comes on, but doesnt cool it down. When I start to loosen the cap (when hot) it makes sounds like there is still air in the system.
Does anyone have any ideals what I should do, or could be the problem. I have heard that it could be the head gasket, but like I said there is no mixture between the oil and coolant.
I need to get this thing running so my son and get off his other end and get a job.
