Does anyone have an old heater core layin around somewhere? I'm looking for some measurements of one
Heater core question
If no one from the future stops you from doing it, how bad of a decision can it really be?Tags: None
hc dimensions
The dimensions with the foam in place are:
6.75" W x 7" L x 1-7/8" DLast edited by bravekozak; 10-22-2010, 07:42 AM.
Thank you
you cant use that as an intercooler, you know that right??? lol jk
Mike, AKA the sasquatch
^ i dont think it would hold the pressure....
Think of the heater core working opposite of what it was designed for, cold water running through the heater core with warm air from the turbo passing through it = water-to-air intercooler
Originally posted by Damkid View PostThink of the heater core working opposite of what it was designed for, cold water running through the heater core with warm air from the turbo passing through it = water-to-air intercooler
dry ice
What you need is one of those dry ice intercoolers with a coil inside to do the heat exchange.
Where to buy dry ice?
Why would I know?
I almost bought a dry ice blaster setup off of the Bay.
It sublimes on impact and does a great job of taking off mold, rust, paint, grease and oil with no mess to clean up.
Check it out...
Time to dry ice blast your Festiva!
Did I mention it is safe to use on electrical systems?Last edited by bravekozak; 10-22-2010, 07:43 PM.
Originally posted by sasquatch View Posti dont think it will cool the air enough.... its not big enough...
Besides, an air-to-air intercooler mounted on top of my engine near the firewall would not be that efficient either since there'd be little airflow moving through it
