oil pan
  • oil pan
    The motor I got outta of 94 protege is 5spd motor. The oil pan is one big piece. I have an auto 89 festiva putting it in. Now the problem is the oil pan covers up were you reach into the torque converter bolts. Do I need to get an auto oil pan and are they interchange or take the oil pan off the 5spd bolt the torq.. up then reinstall the oil pan.
    just got you answer...
      I would go get a Protege auto transmission oil pan. That is going to be a PITA to take the oil pan off everytime you want to remove and install the transmission. The auto protege has a nice big access hole in the back of the pan that is covered with a rubber plug.
      You gonna race that thing?
        I heard they will not interchange. does any body no if the oil pans interchange. this is what the manual one looks like. were the inspection plate goes is one piece.
          The last Protege engine I got from the junkyard was from an automatic. It fit up to the 5 speed manual with the usual cutting of the "ears" off each side to clear the CV axle joints. I have had both manual and automatic Protege oil pans and they both fit with the above mentioned cutting. I've never used the Festiva automatic but I don't see any reason it wouldn't fit when both the manual and automatic bolt up to the B3 block.
