Bp ecu
  • Bp ecu
    How many different ones are there and which is best. A long time ago I found a chart that listed them all but I can't seem to find it any help you have would be great. Also which one has the higher redline. Thanks
    New build on the way .
    probably the miata BP has a higher redline if they did the same lightened crank and flywheel like in the 1.6
    Walth
    Festiva #1: 91 Red L 4/5
      cant use the miata ecu has way different ignition setup.
        just get the bp09 one... i know that one works, its the one i used and its the one most people use... its out of the escort gt with the manual trans....
        Mike, AKA the sasquatch
          I thought the proto ecu had different fuel map and redline.
            yeah...sorry, figured you "couldn't use the miata one" but I'm sure if you could, it'd probably be the best, yeah?
            sorry for not being of much help lol
            Walth
              Theirs the egt and the pro bp09 and bp10. The ten just a higher rev limiter. Also can be used for auto or manual.
                Okay thanks guys
