diaphram/servo
  • diaphram/servo
    good day!
    just wanna ask if where it is connected? the upper vacuum line of the servo..
    here's a photo:
    Unlimited space to host images, easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
    "i am the difference":cheers:
    On the Firewall are a set of Black Vacuum solenoids [V/S] (on a single bracket). Going left to right: 1st V/S , space, 2nd V/S, 3rd V/S, 4th V/S with electrical connections on top. Your vacuum line goes on the 3rd V/S ( on top tube, which sticks out 90 Degrees out from the main body.).
    I hope that helps you out.
      my ride is a kia pride CD-5, only 1 vacuum solenoid (for the A/C) in the firewall..the VS has a 2 vacuum lines with 2 wires (electrical connection)..this 2 vacuum lines,1. below the solenoid is the vacuum line for the intake manifold, 2. in the side of the solenoid is the one that goes to the line in the side of the diaphragm/servo..the upper vacuum line of the servo, that one i don't know where it is connected..
      thanks!!
