Will antifreeze corrode pvc pipe?
  • Will antifreeze corrode pvc pipe?
    -93' Festiva L (B6T swap in progress)
    -92' XR2 Capri (Parts car)
    No
    But, depending upon the type of PVC pipe and the temp and pressure of the antifreeze it could well sofen and burst.
      PVC has poor compatibility with propylene glycol. What do you want to use pvc for anyway?
      Oscar
        chemical compatabilty page link ........
        To use .. select the two materials from first two boxes, then in third option box select "all" and hit "submit"
        according to this it stands up very well
        money pit
        No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
          Ethylene glycol compatibility is A (excellent) but propylene glycol is C (fair). Antifreeze as a chemical is a bit vague.
          Oscar
            my radiator doesnt fit due to turbo manifold and turbo size, so i'm mounting the radiator between the front tranny mount and sidewall and the bottom outlet on the radiator is obstructed by the mount so i need to try and route around it.
            I figured i could try to make somethin with some flex hoses and pvc bends
              Why not use metal pipe? I hear metal is good about not melting.
              Take it back to the back porch, join the 3 string revolution.
                Wouldn't it corrode?
                  Depending on what metal. The engine is made of metal, yet it holds antifreeze like a champ.
                    No the metal will NOT corrode if your cooling system is properly charged with goo antifreeze. If it would corrode it then your engine would corrode. Antifreeze is made to protect metals and lubercate.
                    88 festiva lx, 2.3 turbo rwd swap in progress
                    1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
                    R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
                    00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
                    03' gt, full termi swap 700+ whp build
                    sponsered by,
                    pam pam's junk, dayton OR.
                    Bob's ok tires, salem OR.
                    Clausen Truckin', keizer OR.
                      I just figured pvc would be easier for me cuz i have nothing to bend metal pipe with.
                          looks like I'm gonna try using some copper. thanks for answering my question everyone
                            Copper pipe is used all the time to make up lower radiator hoses on 24 valve Taurus engines. It's a pipe with rubber ends. The dealer wants $196.54 for that piece (ask me how I know the exact amount).
                              use ALUMININUMUMUMUMUMMUMUM ( lol ) but seriously aluminum would work an im sure a local exhaust guy would bend it for you for a buc or two
                              Don't meddle in the affairs of Dragons for you are crunchy an taste great with katsup!!!
