I was replacing the clutch in a 1988 festiva and on the bottom right of the trans is some sort of two wire sensor. Does anyone know where I can get a new one, and the name of the part? One of the wires is broken inside the sensor housing.
Trans sensor
JY would probably be best bet, or someone else on the board... post a wtb..
-Aspire brake swap COMPLETE!
I've got these 2...is this what you need? PM me for 1Originally posted by tycope View PostI was replacing the clutch in a 1988 festiva and on the bottom right of the trans is some sort of two wire sensor. Does anyone know where I can get a new one, and the name of the part? One of the wires is broken inside the sensor housing.
