I was needing a fuel reg. for my Hummm--eeer but did not want to pay 130.00 for it so I found one for a stanza about 40.00 and adapted it to fit if anyone want`s to go this way it works on the correct pressure and is doing good on my car. The vac hose is in the correct place and the fuel return is strait and works ok the bracket needs the wholes drilled out and then slotted out because the holes are not the same as the factory unit.I am allways looking for a less expensive way to keep my rig running and i hope this will help someone else. The part number is----CRB219815
Fuel pressure regulator less expensive.
