which clutch do you recommend me buy? is for the b3 engine slightly modify and will get more modified this week, i am in need of a clutch right now this one is running out. will a heavy duty clutch be the best bet? or the stage 2 clutch? any suggestions
which clutch is better?
Exedy "kevlar" clutch, NOT "organic", they are about 100$ on ebay. I have one on my b6 and I've ran the piss out of it at the drag strip and auto-x and it has never slipped.
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
Bhazard, I think you need to advise him!'93 Blue 5spd 230K(down for clutch and overall maintanence)
I say the kevlar bc my buddy phill has gone through 3 organic clutches on a stock b3 sine I installed mine and he dosent even race his. I personally don't see the point in putting a puck style clutch bc the trans is already so weak that shock loading it all the time will kill it anyways. Just get a step above the oem witch would be the kevlar, anything more is just pointless.
sponsered by,
Maybe those other mods you did have finally wasted your engine!Originally posted by 1993 festiva View Postyea was wondering because i beat the hell out of mine and its running out, dont feel the torque like i used to 2 months ago, ill maybe be putting a b6 long block anyways so ill need it..."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Any festy clutch lasts a while if you remember your car has 63hp. I slipped the hell out of my aspire because i was trying to find some passing power that just wasn't there. The exedy ones are what have been suggested a few times if youre still on a budget. iceracerdude has alternatives since he still uses e trans.1993 GL 5 speed
Yeeeeah if youre burning up stock clutches on a stock motor (or in your case, probably less than a stock motor) you might wanna learn to drive stick.
I pretty much believe neanderpaul when he tells stories of 300,000+ mile festies with factory clutches.
I also cant recommend a hard clutch on a glass transmission. That thing slips for a reason. Its the fuse between the engine and transmission. E-series doesnt take too well to the shock of hard launches as wheel hop.Last edited by bhazard; 03-02-2011, 05:38 PM.91GL BP/F3A with boost
I got to call BS on this. I ran a stock festy tranny with a race clutch on a b8 engine and it held everything I could throw at it. Numerous clutch drops and everything and it held up like a champ and that was atleast 8 months worth of beating before I desided to go f-series hydro with my bp. The festy tranny had roughly 175,000 on it which isnt much. I wouldnt try it with a tranny that has over 250,000 though.Originally posted by 1988festivazoom View PostI personally don't see the point in putting a puck style clutch bc the trans is already so weak.Last edited by 91_festy_Gl; 03-02-2011, 05:45 PM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
ive blown 2 festiva trannys with a b6 stocker, auto-x and clutch drops on the regular WILL blow it up. the spiders are horribly designed and weak, the first trans i blew up shot the spiders out the bottom at a stop light, the second one just dropped them and it wouldint move, its a glass trans and anything more than a b3 is too much if u wanna drive it HARD and drag/ auto-x it.Originally posted by 91_festy_Gl View PostI got to call BS on this. I ran a stock festy tranny with a race clutch on a b8 engine and it held everything I could throw at it. Numerous clutch drops and everything and it held up like a champ and that was atleast 8 months worth of beating before I desided to go f-series hydro with my bp. The festy tranny had roughly 175,000 on it which isnt much. I wouldnt try it with a tranny that has over 250,000 though.
sponsered by,
On a B6? How? B6 stock puts down alittle more then the b3 stock and you blew out 2 trannies? I dont know but my festy tranny is in the shed waiting to be planted back into a stock festy that has a 4 speed and i have never had any problems out of it even with a B8. My brother can vouch for that as he was the one that helped do the build. I guess maybe since mine is a low milage tranny it hold fine for now. I dont doubt what you say it just seems odd that a stock b6 would kill out 2 trannies like that.Last edited by 91_festy_Gl; 03-02-2011, 08:28 PM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
the exedy clutch cost the same as a oem clutch from the parts store!! jesus! why not get a much higher quality clutch for the same price!!??http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
sponsered by,
Just to clarify, I ate up a clutch with unknown history and 257k miles on the car. Id put the cheapest thing in there or the exedy and if it does go don't repeat, just upgrade the trans and a larger clutch comes along for the ride.1993 GL 5 speed
