As some of you may know, I purchased this intake and carb:
As it says, the PCV hole is welded shut. Obviously it was ran without the PCV. I know it's possible, but is there any pros or cons to not using a PCV? If I run it without it, what do I put in place of the PCV valve coming out of the VC? Do I just point the hose away, or do I need to plug the hole, or what? Thanks again.
