Gas Tank / SENDING Unit (Part 1 of 2)
…. When I POSTED “Inside Your Gas Tank “ (Ref. http://www.fordfestiva.com/forums/sh...ad.php?t=34104 ) I removed and cleaned up the fuel Pick-Up Line and Sending Unit, see pics. The battery went dead in the camera and consequently DIDN'T get “before pics” to show just how CRUMMY it was before I cleaned it up.
FILTERING SCREEN: but, you should get some idea from what it looks like now. The REDISH BROWN stain around the skeleton portion of the screen pick-up was just totally covered, the whole FILTERING SCREEN with this thick same color crud. Used an acid bush, an equivalent brush might be a toothbrush, and gently and very patiently with a good detergent lightly scrub the screen under running water until it gets to looking like the finished product in these pics. After cleaning up the FILTERING SCREEN it fits too LOOSE on the PICK-UP pipe and I had to use a twisted wire wrap twisted tight enough to grip the PICK-UP pipe, see pic.
