I locked my keys in my car, I'm at walmart. Anything I can do other than call a locksmith?
Help asap!!!!
Heard you can jimmy the lock with pretty much any slim object. Push it down in between the window molding and the door and go to work on it! Never tried myself but heard it's easy!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Well, on mine anyways, any key will unlock the drivers door. Hell, even a screwdriver or something will. Any chance you left your hatch unlocked?The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Coat hanger(metal) with a "U" or "V" shape at the end.
Push it down between the out side weather strip and glass near the gray plastics manual lock engagement.
The bottom of the plastic piece is flat.
Use the "U" or "V" piece of the coat hanger to push up the lock.
About 5 to 10 seconds work without practice!'93 Blue 5spd 230K(down for clutch and overall maintanence)
x2Originally posted by Pu241 View PostCoat hanger(metal) with a "U" or "V" shape at the end.
About 5 to 10 seconds work without practice!Never Hire a Boy to do a Man's Job!!
I once folded a paper clip to a long "U" and slid that in the door lock and used a flat screwdriver to turn the lock, it worked just as fast as a key
^^with my green festiva I almost did that once since I had spare glass lol
It's double frustrating/embarrassing to get locked out of a festiva. Passersby will be like "when i was in football me and the o-line coulda carried it home for you," etc.1993 GL 5 speed
