Access Trouble Codes
  • Access Trouble Codes
    I am at work and do not have my manual with me, so I am asking for a quick answer so I can fix this issue at lunch.
    ON my way to work my check engine light came on. Yesterday I replace the valve cover gasket and throttle body gasket so not sure if something I did in the process caused the check engine light. I just smogged the car on Thursday.
    Could someone remind me what wire is jumped to ground on the OBD system and what the fast/slow blinking correlates to? I know I have to ground one of the connectors in the little three plug wire near the fire wall/strut tower, but do not recall the process. If I can get the answer soon, I can be ahead by the time I get home and hopefully repair it this evening. This is somewhat critical as I am trying to sell the car.
    On my '93, it's the singe pigtail connector with a yellow wire and green tracer. There is shrink wrap tubing somewhat covering the wire, so you have to pull it back a little.
