ATF In The Engine Oil
  • ATF In The Engine Oil
    .... Has anyone here used a little bit of ATF in their oil change as a means of keeping things CLEAN, especially LIFTERS on a regular basis? And if you have, how much and how has it worked out for you?
    A hunch is creativity trying to tell you something.
    I've never used ATF for that but I have added Marvel Mystery Oil in my trucks that sit for long periods of time so it would help with lifters and keep valves from sticking.
    The only thing I've used ATF for in an engine is to help clean carbon deposits off the tops of pistons. Used to pour a little down the carburetor while the engine is running or suck it into the intake tract via a vacuum line on EFI cars.
    WWZD
    Zulu Ministries
      Way back in the day my father and his buddies used to do that. They would add about 1/2 a quart to the oil before an oil change. You let the car run for a bit, shut it off and when it's cool, change the oil.
      I do the same thing, except I use Marvel Mystery Oil. Seafoam works the same way.
        if you do put atf in your crank case only put it in right before and oil change, i personally wouldint do it, if your looking to just clean gunk out of the engine get some engine flush, if you want to clean carbon from the combustion chambers u can simply get a spray bottle of water and mist it through the intake tube at a high idle, this will cause steam and remove must carbon buildup.
        88 festiva lx, 2.3 turbo rwd swap in progress
        1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
        R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
        00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
        03' gt, full termi swap 700+ whp build
        sponsered by,
        pam pam's junk, dayton OR.
        Bob's ok tires, salem OR.
        Clausen Truckin', keizer OR.
          if you have a heavy varnished engine ( brownish-gold buildup) you can add a 1/2 quart a few days before you change the oil, and drive around with it without damaging anything. its still petroleum based so no big issues there, just keep in mind it will thin the oil a bit. so just don't hot-rod it. as far as using it all the time, i guess used accordingly, untill its clean it wouldn't hurt anything.
          Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
          Dennis
          93 GL In progress BP/hydro G
          15 Mitsubishi Mirage daily
          88 Dakota tow pig
            When I had auto mechanics class in high school back in the 80's, the teacher would do that. So I came up with a "great" idea. I bought a windshield washer reservoir with pump, installed it on my 77 Mustang, filled with ATF and then ran a hose to the carb. James Bond smoke screen. :glasses7:
            Rick
            1993 Ford Festiva
            2000 Ford E350
              ^^ :laughing3:
              I had the exact same thought the first time I saw it done! It smokes like CRAZY!! We used to cloud up the whole neighborhood LOL I'm glad I get along well with my neighbors and they've gotten used to all the "car stuff" we do :mrgreen:
              WWZD
              Zulu Ministries
                ATF worked miracles on my old service truck. Lifter noise, the odd/fluctuating oil pressure and one or two of the leaks (!) magically vanished. I've yet to try it on the new one, which has all those problems and more.
                If you do it, don't use the Dex/Merc specific stuff. The friction modifiers in that stuff do funny things to an engine. Use the cheapest, most ambiguous 'gas station' ATF you can find.
                  Originally posted by 1988festivazoom View Post
                  if your looking to just clean gunk out of the engine get some engine flush...
                  If you have never used "Engine Flush" before, take the warning on the can seriously. DO NOT drive your car while that stuff is in your crankcase. It's a solvent and will thin your oil out to dangerous levels.
                  Also, the stuff has a tendancy to loosen sludge that's built up around worn seals. Don't be surprised if it creates leaks around old seals.
                    Put Type F in the fuel. It's been confirmed that it does clean the top end but does nothing for the rings. Look up "MMO piston soak" and try that. Thinning out an oil can work out all kinds of problems where the old thought was to use a thicker oil. I used motorcraft 5w-20 in the 1.3 aspire a whole year and it ran better and got quieter week after week.
                    On a 1988 f250 i dropped the oil pan and shot it with a pressure washer from below heh. That was fun and it ran great afterwards. That truck is still on the road too.
                    1993 GL 5 speed
