Hi fellas, I'm finding it impossible to find 100cpsi 2" metal cats... I can only seem to find them in 200cpsi. 2.25" seems to be the smallest 100cpsi available. Is there any reason for this do you think?
2" 100cpsi metal cats?
What?1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
How would a 100csi be any more restrictive than 200csi?
The 200 will have smaller holes, but twice the holes in the same area should mean that there is more surface area to the holes.
The surface area of the holes in a cat is generally larger than the cross section of the pipe they're fitted to, to reduce pressure differential across the catalyst.
