check engine light
  • check engine light
    Do the tach clusters not have a check engine light? If so why not....
    I'm sure they do
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      Yes they do, why are you asking.
        I ask because i dont see one on this cluster ( orange tach cluster)
          Turn your key to the "ON" position and the it should come on, unless the bulb is burnt out or something. The CEL is located below the tach.
          '90 LX
            wybnrml, thank you for the simple answer, however mine only has the belt and rear def. below the tach. whats up?
              I have an orange tach cluster in my 88 and it has a check engine light.
              91 Festiva GL "Scrat"
              82 Honda Goldwing GL1100i
              85 BMW 535is "Brunhild"
                Here's a pic were is the cel?
                  Your CEL should be where the red circle is.
                  My guess is the bulb is blown or weak. I would pull the cluster and and check the bulb, connections, ect. If the bulb looks burnt out take it into a parts store and they should have a replacement. To pull the cluster you need to unscrew the speedo cable from the transmission, remove the bezel from around the cluster, it is just a few screws. Unscrewing the speedo cable gives you enough slack to pull the cluster out to unplug the connections on the back.
                  '90 LX
                    Thank you wybnrml, I was getting ready to go out and take a pic of mine.
                      This is getting wierd, i checked again and there's no engine icon in the spot you circled. Even with the bulb burnt out shouldn't there be a icon in that spot?
                        Without a backlight they are very hard to see. Try using a flashlight and shine it at different angles. It may illuminate it, but it may not. On mine I can use a flashlight and illuminate the CEL, belt light and rear defrost light, but I can't even see the Oil, Charge, or brake without it being lit up from the back. But I'm sure its there.
                        '90 LX
                          IIRC, the bulb is a 194, commonly available in Walmart for cheap!
