WDYT? = What Do You Think? I've got more trimming to do, planning on lining it up with the edges of the hatch. I'll glue it down and fillet the edges to blend it in as sort of a step onto the blue bumper, not trying to make it seemless. The bottom will get attached using the existing screws, may trim the old ones off the blue bumper, the top will get blended into the little step under the hatch, it's edge will also be held down with holes drilled thru both pieces and the "Christmas Tree" pin clips (like hold your plastic inner fenders to the metal outer). The whole thing will then be sprayed 'bumper black'.
Only question is, what do I use for the glue? I know I need to strip the blue paint off to bare plastic, what do I use for that? Mechanical? Chemical? I used some chemical to strip a Dodge Shadow bumper and I don't think it got totally neutralized as when it came back from MAACO, it looked horrible.
