Another 5-spd Transmission Question
  • Another 5-spd Transmission Question
    Guys -
    Does a 4-spd shifter work in a 5-spd transmission?
    Heard from someone that it will work.....gears 1-4 and Reverse work as normal and you just have to push the shifter to the right and forward to get the 5th gear.
    Is that correct??
    If so, I would not have thought that the 4-spd's below-the-floor linkage would have been able to 'grab' / shift into that 5th gear.
    88L - 'Twistiva' - 'The Fusion of Man and Machine'
    93L - 'Vextiva' - Airport Car
    If you mean the shifter, it will interchange.
    The shift pattern is dictated by transmission internals.
    (paperboy 23) 88 Festy Blue, aspire Engine/trans/efi swap,
      Same part. The difference is all in the transmission.
      Going old school...
        OK, good to know!
        Several months ago I saw a "5-spd shifter" advertised on e-Bay and I then incorrectly assumed that there was a difference between a 4-spd and 5-spd shifter.
        Thanks, guys!
          Only difference is the stamp on the knob
