Im taking my new inquired knowledge of circuitry from university and i'm attempting to convert the vaf system to maf system. The plan is to have a standalone kit to plug straight into the vaf wiring then plug the unit into the maf sensor no need for a obd2 ecu or standalone ecu.
Ive done a lot of reading and as i understand there is two types of maf sensors, one that users the temperature of a wire (hot wire sensor) to output a voltage and one that uses Kármán vortex which outputs a frequency, higher the rpm higher the frequency.
Both of these seem promising, although the frequency maf will be a little trickier.
If you have any information you feel necessary to help please share or even broken maf or vafs you have you would like to share.
