one MORE use for PB Blaster...
  • one MORE use for PB Blaster...
    wasp/hornet killer!! works faster than the real stuff.
    anyone have other uses (other than the obvious)?
    Lubricater ,
    Edit: is this even a word? Lol
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      PB Blaster is good stuff. :blob5:
        spelled with an "o" and yes, it is a word.
          I thought it looked funny after i looked at it.
            I haven't tried it with PB but I've found that WD-40 makes great starting fluid and is easier on the engine
            Maybe I'll try PB next time instead!
            WWZD
            Zulu Ministries
              PB won't light off, just smokes...
                i witnessed this. he sprayed them and the ******** dropped like flies in a zapper! almost instantanious!
                  I thought it looked a little too oily to work. Oh well
                  And to get back on track...it works good to remove sticker residue
                  WWZD
                  Zulu Ministries
                    Silicone spray works as a decent starting fluid (at least for diesels, anyway). I swear by pb for anything rusted on. I've used several industrial/institutional products from a bunch of manufacturers and I don't think any of them do even half as well as pb.
                    It's good for dissolving styrofoam!
                    Sent from the bathroom via crapatalk
                    91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
                    92 L 5sp "Red" RIP
                    95 Grand Prix SE DD
                    Wife's Stuff:
                    89 L 5sp "Carby Car"
                    97 Aspire auto "Pink Panther"
                    Build Thread
                    Spring 2013 IndyStiva:
                    http://www.fordfestiva.com/forums/sh...eet-April-20th
                      So PB is good for making homemade napalm :mrgreen:
                      WWZD
                      Zulu Ministries
                        The side of the can shows a styrofoam cup melting LOL. Does what it says and says what it does. How is this stuff even legal in california? I'm about to finish my last can and haven't even started the rear suspension. 3 bucks at biglots, cant go wrong.
                        Yes, i imagine you can make a sticky goo and mix it with gas.
                        A trick to make it last even longer is to wet your parts with water and spray PB, it will flow and break it up using less product. My uncle used it as a gun cleaner and i thought it was because he was cheap, but recently i read that they sold it repackaged to companies as a gun cleaner so he wasn't stupid at all.
                        1993 GL 5 speed
                          I've used it to seat off road tires before when I didn't have starting fluid or denatured alcohol.
                            I have used several products also....didn't think there was anything that would come close. Well we started selling this stuff called Free All , I think it is right up there with PB blaster.
                              I've used some stuff made by BG called In Force. It's as good or better than PB (IMO) but you have to order it so I just stick with the off the shelf PB.
                              WWZD
                              Zulu Ministries
