Just thought id post this up to help others if they were to attempt there own hitch.
I was in a rush when doing this so it didn't come out the exact way i wanted it to. I used a 2 to 1 1/4 inch receiver adapter from harbor freight 13.85$ with 20% off super coupon. I planned to just cut the square section out of bumper slide the receiver in and weld around the front and backside and be done. Come to find the thin festy bumper cannot be welded so i had to quickly improvise and came up with the pictured product. 2 1/2 x 3 1/2 stainless bolts through the piece of bed frame welded to the back of the hitch which this is what made it stick out so far . Drilling through the bed frame and bumper was a pain in the .
In all I only wanted the 1 1/4 ch section to be sticking out as its only about 4 inches, but this is what it came to and I should be able to fix at a later time. I also still have to weld on some safety chain loops and get a different style ball arm combo to reduce length and paint the bumper black but i threw some clear coat on it to slow the rust. ENjoy
It would also avoid the big bar of metal hanging underneath the rear end for all the other "conventional" heavy duty Class II plus hitches we've seen done up between the tow loops.
