Just wondering.. if any of you have the time can you see what your voltage reading is at your fuel pump when cranking with no clutch, and cranking with clutch, and also key on - engine off?? please!
Voltage at fuel pump question??
should be battery voltage minus 0.2-4 VDC cranking. if you're not seeing that, then you have an issue...Trees aren't kind to me...
