Tank
  • Tank
    is there any difference between the fuel tank for a fuel injected automatic 92 and a 89 carb? (bolt pattern or size?)
    :wav:
    Clink... Clank... BOOM!
    As far as the tank goes, i dont think so. But remember the cap is different because of the fuel pump and wiring etc.
    Dont quote me on that.
    93 Ford Festiva WA (project car)
    98 Ford Festiva WF (aspire)(parts car)
    98 "Gloria" Toyota Corolla AE101 (daily driver)
      fuelly's have an extra return line. I can't recall if the sender hole is the same or not. But I will trade you a fuelly tank for a carby tank if you have one.
      91 Festiva GL "Scrat"
      82 Honda Goldwing GL1100i
      85 BMW 535is "Brunhild"
        fuel tanks are different carb to efi. They are not interchangable. The efi tank has a sump well that the carb tank does not, and the pump/sending unit ports are different sizes.
        Jim DeAngelis
        kittens give Morbo gas!!
          Thank you FB71, I knew someone would chime in.
