/Facepalm moment
I remember someone posted this so I couldnt help to repost it. LMFAO!
I have never personally forgotten to torque them down, but I did pick up an Accord for cheap with that problem when I bought my parts car for the CRX. Guy didn't know what was wrong with it. He had swapped it from auto to MTX about 20k before and finally a couple bolts came out enough to pinch the clutch and keep it from disengaging. That was a good little car for a while, finally sold it to wifey's brother who blew up the trans a few thousand later :lol:
I usually get excited on the final steps and forget to connect the coil to dis wire, or hook the fuel lines up backwards ....
I had some torque converter bolts come out on a neon I fixed for my sister... I had even loctited them!
Originally posted by IdealSociety View PostNow at least i dont feel like im the only person to have ever made such a silly mistake!
Originally posted by Damkid View PostI've done that before.... forgot to torque the flywheel bolts :lol: it happens
flywheel/clutch as mentioned:
im just glad i dont have to buy another clutch, funds are tight atm and i could probably only afford a stock style disc.
I got to fix one of those moments ... One of our other shops switched out a sixty series Detroit, and did the same thing !!!! When it got to us 150 miles away ,there was one bolt left with four threads hanging . Not to bad it only needed a six thousand dollar crank .. I rebuilt it while it was out costing 21,000 total ..
/Facepalm moment
pulled the last motor i put in the BP car that knocked after a minute of running. i was worried my 6 puck clutch had let loose or that the 4th cyl was just absolutely knocking itself to pieces.
turns out, when i did the rear seal, i never retorqued the flywheel down and they were only in hand-tight.
no damage done thankfully, but it does make me mad that i totally spaced out something as important as that when i put the motor back together
anyone else ever have a /facepalm moment like that?Tags: None
