Injectors
  • Injectors
    Will a b3 run off of bp injectors.
    Why would you want it to. There is no gain
    Ford Fester
      you might be able to get it to run if you adjust the VAF way lean, but it will be really rich. I would be worried about running so rich that you wash the cylinder walls with gasoline and it gets into your oil... the bad things happen. If you are running forced induction then you might be ok.
      Facebook Me!
        what about b6t injectores
          those flow even more than a BP...
          Facebook Me!
            injector envy?
            Jim DeAngelis
            kittens give Morbo gas!!
              Install a tiny little lawnmower carb on the top of each injector hole and adjust them with something from the plumbing section of a hardware store.
              No one else has this! You'd be unique.
              As for BP injectors in a B3, someone has already brought that up.
              May as well be unique!
                A BP ECU bumps up the HP of a B3 to around 100 at the wheels. Some kid did it here a while back.
                91GL BP/F3A with boost
                  joke?
                  :cry_smile: RIP. 91 Ford festiva BP swap
                  1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
                    Quote:
                    Originally Posted by bhazard:
                    "A BP ECU bumps up the HP of a B3 to around 100 at the wheels. Some kid did it here a while back."
                    McKabe asked:
                    "joke?"
                    No joke, but it requires SAE trained monkeys under the hood yanking on various engine parts and coordinating timing pieces.
                    It's kinda like the cutting edge of bioengineering and hasn't been published much except in professional journals.
                    It's also a myth that Jane Goodall was involved. She worked with chimps, not monkeys, and she never attained SAE certification in her doctoral program.
                    I hope that settles this. We really don't want amateurs combining the wrong DNA with cast or forged parts. If you wonder why not, read Mary Shelly's account of the work of a Dr. Frankenstein. Bad things can happen. Maybe in this case, the H2N5, the "Monkey Flu." The Big One could be just around the corner!
                      Im not trying to get more power just trying to get the b3 running with the parts I have
                        A BP ECU bumps up the HP of a B3 to around 100 at the wheels. Some kid said it here a while back
                        There, I fixed it.
                          There, I fixed it.
                          I see what u did there.
                          2008 Kia Rio- new beater
                          1993 Festiva- Fiona, DD
                          1997 Aspire- Babyspire, DD
                          1994 Aspire - Project Kiazord
                          1994 Aspire- Crustyspire, RIP
                            Cestelle wrote:
                            "Im not trying to get more power just trying to get the b3 running with the parts I have."
                            Oh.
                            Okay, how do you know your B3 injectors are bad? Have you cleaned or tested them?
                            Have you troubleshooted the rest of your FI system?
                            If they're really not usable, then I'd go to a 'yard and pull some B3 injectors.
                            If you absolutely can't find any B3 injectors, and you can't afford to order new ones, the next step up would be B6 injectors. I'm not sure they'd work or be safe, but they'd be more likely to work okay than BP ones. (However, I realize you probably have a BP sitting around and not a B6.)
                            Sorry about the trained monkeys, etc. Like the others, I thought you were looking for a "turbo power shortcut."
