oil light help
  • oil light help
    My oil light stays on with key off/out. I unhooked the battery for a day and it still does it? No fuses blown I didn't touch anything. Pressure sensor is plugged in and light goes off with key on.
    Ford Fester
    Kinda sounds like a stuck relay or something of that sort but I don't think there is one just for that . Try an ecu if you have a spare .
    New build on the way .
      Im guessing auto ecms are different then manual?
      Ford Fester
        Which car is it that's having the light difference? 90-93 ECUS are universal B376
        Andrew Walker
        Current Daily Driver:
        89 Nissan D21 SE V6 5 speed 4x4
        Projects in the works:
        84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
          Oops. It does not even go through the ecu !! Maybe the icu ,Duh is what I ment sorry !
            ignition control unit?
            Andrew Walker
