So when I grabbed a b8 from the junkyard yesterday I also grabbed a nice turbo. Its a garret from a Volvo 760. Only drawback is it had coolant lines going to it also. I took it apart last night, cleaned it and turned the housings so it will line up nice. Anyone have any experience with water cooled turbos? Can I plug the holes? It has an internal wastegate and I read some on the web and it sounds as if its set at 7 psi.
turbo??
B8 AND a turbo!? Nice snag!!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
I wouldn't delete the water cooling. You're asking for early bearing failure. Just route one of the heater hoses thru it.Jim DeAngelis
kittens give Morbo gas!!
I have used those turbos before without water cooling ( you don't even have to plug the lines if you don't want to as it makes no difference) and beat them like a junkyard turbo should be beat with no problems. Synthetic oil and not shutting the engine off right after running it hard keeps it from grenading. I think that's a 50 trim t3, they match well with1.8 liter engine.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
^ x2. Mine has the water holes with nothing hooked to them. 40k and no issues with the turbo-Greg
Redneck Engineer
FOTY - '09
^^^ hmmm... ok then!
I was going off of what a Honeywell rep told me. Talked with those guys alot when I was handling VGT failures on the VT365/Powerstroke 6.0L. She said they have tried both with and without water cooling, and found a significant difference in bearing durability. She said without water cooling, the turbos had a tendency to coke the oil after shutdown. I know this was a major concern on the VGTs, as far back as the Mopar Turbo Is and IIs in the 80's. I guess its not as big a problem on fixed geometry units.Jim DeAngelis
If it's a water cooled turbo, I'd route some water through it. It's really not that difficult, the B8 block should be tapped for it like the BP block is
My 2¢1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Originally posted by FB71 View Post^^^ hmmm... ok then!
I was going off of what a Honeywell rep told me. Talked with those guys alot when I was handling VGT failures on the VT365/Powerstroke 6.0L. She said they have tried both with and without water cooling, and found a significant difference in bearing durability. She said without water cooling, the turbos had a tendency to coke the oil after shutdown. I know this was a major concern on the VGTs, as far back as the Mopar Turbo Is and IIs in the 80's. I guess its not as big a problem on fixed geometry units.Last edited by Advancedynamix; 10-06-2011, 03:10 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I wasn't saying DON'T do it. If mine were under the hood I would have it hooked up.
My setup does NOT require as much cooling as others.
Rear turbo FTW again....-Greg
Redneck Engineer
FOTY - '09
Originally posted by Advancedynamix View PostThe vnt units run very hot and are usually undersized for the application.Jim DeAngelis
