I really need to figure out whats going on, the car has a constant rumble comming from under the front driver side somewhere, and occasionally from the passenger side, especially when I let off the gas, but not exclusively (does it when pushing the gas too sometimes) around corners it will "wobble"...not the clicking sound my aspire made when the cv's were bad. It's a 99 mazda 626, anyone know whats up from what I'm describing. I'm just stumped its killing me.
Rumbling noise
Rumbling noise
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!"Tags: None
Quick guess. Wheel bearing.Festiva: Because even my dog can build a Honda.
3X wheel bearings
Jack it up and check for play.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I was thinking that, but really hoping not, they're a PITA to replace from what I hear, like festy/spire bearings. I was also thinking it may not be that because my van does it too occasionally (not often) and I just put a new wheel bearing/hub assembly in it in march/april of this year.Originally posted by JPT View PostQuick guess. Wheel bearing.
If that turns out to be the general consensus I'll replace it, I hope to not end up putting a whole new front end under this car before I figure it out like I ended up doing with my aspire.
I have jacked it up, more than once, and shook the crap out of the tires on both sides, honestly there is NO play that I can tell. I even used a 4' pipe under the tire like someone suggested and the strut/spring moves with no wheel play. The car sat for 3 years, maybe the bearings are tight but have a flat spot like tires develop after sittting?2008 Kia Rio- new beater
your 626 has cartridge style bearings, much easier to replace than the festy units.Trees aren't kind to me...
Yea it's another one of those subjects the haynes manual doesn't go into detail about and tells you to have a shop do it.. it's supposed to be bearing/hub assemblies tho, so I figure it's one of those torch and tap deals like with the van. Either way it's a pita lol..2008 Kia Rio- new beater
I would do a complete look over. check your lca's, sway bar bushings, ball joints and pinch bolts, strut-to-knuckle bolts...etc
make sure your lug studs are tight first to rule them out
and then start marking stuff off the list. If I were you, I would completely take off the knuckles to check how tight your joints are.
yeah it could be your bearings but who knows but you...
I have looked it over, a couple times, I've put wrenches on the stuff to twist for play and haven't figured it out yet, I did replace the tie rod end on the driver side, but obviously that wasnt this problem (it was banging really hard the old tie rod wasn't tightened down enough i think.)
The hub/bearing assemblies are only on the rear, the bearings are replaceable on the front w/o changing the hubs..i have a general idea of how it's assembled, but does anyone have a link or can enlighten me further on how to press out/in the new bearings? What tool do I need to press them..? I've heard its something you can rent @ azone but i'm not sure.
It's a 30 dollar part, I'll attempt it on the driver side in a few days and if it fix's the problem i'll do the passenger side...and check on the lca's while I have the knuckle out....2008 Kia Rio- new beater
I've not done it yet myself but you can rent/buy a puller or buy a slide hammer to get it apart.
AFAIK you can reassemble everything and torque the axle nut to spec (130?) and it's pressed right where it needs to be. no guessing like shops have to with their vices or whatever they use. I know of at least one person who has done it that way with daily driving and it was months ago now. no issues. but...search is your friend and I'm not accountable for any mishaps other than my own.
I watched Arty and Will do the job at Madness and all they used were some sockets and a hammer along with a bearing install tool......made it look like a piece of cake. I would hit Arty (Festyboy) up and ask procedure."FLTG4LIFE" @FINALLEVEL , "PBH"
