I've done quite a bit of reserach in the last few weeks on converting one of my festiva's to CNG. Actually this kit I am looking at just ADDS CNG, so the car will still run off Gas/CNG at the flick of a switch. Here is some of the key points infomation I have learned.
-CNG is 130 Octane, and runs more efficiently with a higher compression ratio engine, and our 9.4:1 ratio for the B3's isn't a bad candidate.
-Since CNG is a gas, MPG wise everything is in "GGE" (Gas Gallon Equivalent). So, i have emailed some people and with my 37 mpg average now on gasoline, i should be around 34-36 mpg CNG gge.
-This is very desirable for the folks in Oklahoma, as the gas is CHEAP ($0.78 GGE) and the fill stations are abundant compared to other states.
(See this link for a map with current CNG prices- http://www.cngprices.com/)
-Few 'issues' with the tanks- 1st is tank space. 2nd is tank prices/certification. 3rd is Tank GGE size and efficiency.
Issue #1- so i'd remove the rear seat, to fit my 16" diamter and 48" long tank(s).
Issue #2- Tank Types are 1 thru 4. Type 1 is cheap/heavy (metal), Type 2 is metal/composite and as weight goes down, price goes up. Certification- I can find Used Tanks on Craiglist for cheap- but their certifcation is either expired or about to expire. I am looking for New Type 1 tanks, and they go for about $1000 for a 9 GGE Tank. Recertification is a bear/ expensive, if you can find some one to do it, which isn't very many folks.
Issue #3 Tank size is in GGE. So as an example, a 9 GGE tank will only hold that depending on temperature outside, and rate of the CNG fill. Faster you fill, hotter you get, and with the tanks rated at 3600 psi (some 3000 psi) you fill at a local station (fast) and your tank is HOT and then has to COOL after you leave, so your 9 GGE is really a 7-8 GGE Tank.
So that means at say 35 mpg GGE for 8 GGE tank is a range of only 280 miles. And a 9GGE tank is on the larger side for a tank. So the CNG guys complain that the range between fill ups is shorter.
But still kind of nice, then just flip switch over to regular gas to make it to the next CNG fill station.
-So I put together an excel sheet that has CNG vs Regular Gas. See attachment.
-My rate of return will happen at 22,000 miles from installation, and then I will be only paying ~$.78 per GGE.... and thats appealing.
-But- this car is already 20+ years old, and I would want to put another at least 100K on the car after now.. (Definitely doable) But other people normally put this CNG conversion on newer cars so then they can fully utilize the CNG cost savings...
There is a kit from EWS http://www.ewsews.com/cnghome.html
that has this kit for $600 minus tank and valve.
Thoughts? Any other things I need to consider ahead of time?
