Heading into my first winter with the Festy. Just curious how these do if they are sitting outside when its real cold. Do I need to look into any kind of a heater on it?
winter starting
Not a direct answer but I'm sure someone with a non carby will answer, but my 89 L carby has never been plugged in and has always started, sometimes with more pumping than others lol. Northern MN gets mighty cold too btw. Although I can't tell ya what yours will act like.Mike Holmgren
Thief Rvr Fls, MN
1989 Festiva L, carb. 4 spd.
"If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
My mom's from Wisconsin and had a champ when she lived there for a while, she said that without the block heater she either parked it basically under a snow drift to insulate the engine, or always park facing south, lol, keep it out of the wind and you're probably goodOwner of:
1991 Red Festiva L, 5 speed (Swagger Wagon)
In progress:
BP+G25MR swap, Kia rio axles hopefully.
Here in South Dakota my cars all set outside. Only problems I've seen are: Windows do not like to roll up if you put them down, doors freeze shut, and they like to hydroplane in slush. They have never failed to start!!! Never PLUGGED IN!!!Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Stock festiva's are amazing in the snow, I went field bombing in a festiva in the middle of winter once and never got stuck
ive never had my stock festiva not start even in -35* (not counting wind chills) temperatures.
granted, unless you have synthetic in the transmission case it does get pretty stiff for shifting till its been down the road a few good miles! Dont think offhand ive ever gotten stuck in it either, those skinny tires just cut through snow, only thing better would be 12" snows or just as skinny 13" snows but ive never needed them so ive never tried.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
except for tornado's and wicked witch'sOriginally posted by gdawgs View PostYou have nothing to worry about in Kansas."FLTG4LIFE" @FINALLEVEL , "PBH"
I have not in 7 years had to use the OEM block heater. However a charged and good battery and thin (5w-) engine oil in winter really help. My 86 F150 has the identical battery (terminal locations and width and length) to a Festy except for some added height (but still within the Festy fastener range) and I've been buying that type of battery ever since.
I have had three festivas in the last 13 years. I live about 1000 feet from lake Ontario with gusting winds, ice, rain and temperatures that would circumsize you if you pee outside and they have never let me down. just keep in mind that you need to keep up with the simple things like cap, wires, plugs, correct oil (5w30) and air filter. I have as well put a piece of plastic card board from a real estate sign in front of the rad so the engine will warm to a proper operating temp in those colder weeks so that I can have warm air inside the car.
Hey Bdubya, your not all that far me, cool to see another member from southern Ontario
