oil light on after key off
  • oil light on after key off
    Anyone else had this problem? Goes off with key in access or run but on key off or out. Draws my battery and pisses me off. This is my second festy with this problem.
    Ford Fester
    I had the same thing happen on mine and it turned out to be the oil pressure sender on the back side of the block under the intake manifold. Replaced it and the problem went away.
    Ian
      I was thinking the same thing concerning the oil pressure switch, but wanted to check schematics to see if that was possible.
      I guess it is!
