worlds smallest v12 engine...lol
Amazing, and he did it in under 10 minutes.sigpic
It's too bad it's not actually an engine, it only spins when you pump compressed air into it.
(notice how there are no spark plugs, wires, or a distributor)
The machining and craftsmanship are top-notch though, it's an incredible little model.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
This one does though.Originally posted by Rocketman View PostIt's too bad it's not actually an engine, it only spins when you pump compressed air into it.
Woo! Jeremy Clarkson!In love with a MadScientist!:thumbright:
that craftsmanship is phenomenal!
-Aspire brake swap COMPLETE!
