is oil in the radiator usually just a bad head gasket or is a crack more common?
oil in radiator?
sign of blown head gasket...check for anti-freeze in the oil too."FLTG4LIFE" @FINALLEVEL , "PBH"
blown head gasket..
another sign to look for.
take the radiator cap off, then start the car.
you will see water moving around as a normal condition.
With a blown head gasket you will see bubbles in the water. this is a result of cylinder pressure being pushed into your coolant passages.http://www.youtube.com/watch?v=s8SilV257aM
1999 SVT Lightning #1212
1993 tube chassis Festiva 351w (shooting for the 9s)
1980 Maples jet boat 455 olds
1991 Chevy custom one ton dually
1988 Mustang N/A 385 w/doug nash 9.88@137 (sold)
2001 GSXR-1000 turbo lowered & extended (sold)
1988 S-10 468 BBC lowered & body dropped (sold)
on & on
Sounds like that one isn't too bad yet, check the head for any needs and replace the gasket. Running on coolant can hurt o2 sensor, Cat, and scuff the bore. If it hydraulics and your starting system is good it can damage internal rotating parts, when you try to start it.Reflex paint by Langeman...Lifted...Tow Rig
Is your car an auto trans or a manual? If it's an auto, it could be getting trans fluid into the radiator via the trans cooler.Originally posted by tkannegaard View Postis oil in the radiator usually just a bad head gasket or is a crack more common?Brian
If you pull the head off to replace the gasket.
Take a straight edge across the head surface to look for any warp.
If i remember correct, I think anything under .003" is ok. any more than that and you'll need to get the head milled.
on a side note,
milling the head will increase your compression ratio giving you more power!http://www.youtube.com/watch?v=s8SilV257aM
on & on
I recommend having aluminum heads re-surfaced, regardless of how flat they are. It's not 100% required, but it greatly increases the chance of getting the best possible seal on the head gasket. You will get the optimum surface finish for the gasket and there will be no question about it being flat. Most factory gaskets are a real pain to scrape off, and you end up gouging the surface. Even using an abrasive wheel can scratch the aluminum and have a detrimental effect on gasket seal. Nothing sucks like having a new head gasket leak.........I'd rather spend the extra $40 and enjoy the insurance.Brian
if you have the money to get them milled, absolutely.
But sometimes your on a budget and thats not an option.
Im definitively with blkfordsedan, mill them if you can.http://www.youtube.com/watch?v=s8SilV257aM
on & on
replacing radiator for giggles while im at it with timing belt tentioner hoses and water pump
