Harmonic Balancer
  • Harmonic Balancer
    Hey everybody ive got an odd question. I had to rebuild a '93 Festiva engine. I replaced the block and used the crank that came with the replcement block. However, it did not come with a Hormonic Balancer. I tried to use the Balancer from the old crank, but unfortunatly it was too small. I called the person i bought the replacement block and crank from but he didn't have a Harmonic Balancer.
    Does anybody know where i can find a replacement Harmonic Balancer that is large enough to fit on replacement crank? Not sure how many differant sizes there are, but it is a larger size. Any info is greatly appreciated, Thank-You!
    .... An unusual situation. I wonder what happen to the original??:scratch:
    A hunch is creativity trying to tell you something.
      If your replacement is from a 93 also then I think you will need to get one from a 93 only. I believe they had a larger crank snout then the rest of the years.
