I have a stock bpt manifold and a turbo off a Volvo 760. Anyone know what flanges these are. I need to make or buy an adapter so I can use the Volvo turbo on the bpt manifold.
Turbo and manifold flange question
If the Volvo uses a T3 flange then you can try to find a BP26>T3 adapter. Someone had a bunch made on Clubprotege at some point, putting a WTB would probably get some hits.
Otherwise you're on your own for an adapter1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
If you don't mind me asking fester, what kind of manifold is that? It doesn't look like the others I've seen!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
http://www.jgstools.com/turbo/index2.html. try this place very good quality stuff.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
