Anyone ever replaced one. I bought a festiva that i am fixing up and the previous owner had afro engineered a new ignition switch into the cigarette lighter socket. Luckily they didn't splice any wires in so wiring is the easy part. What I am stuck on is the ignition switch itself looks to be riveted in place. Didn't know if they was a couple secret bolts that i dont know about. I will post some pictures....Thanks.
Ignition Switch/Tumbler
Those "rivets" you speak of are the bolts
Some folks try to get in there with a dremel attachment to slot the heads so you can use a flathead screwdriver on them. I usually go in with a hammer and a punch and start on one side tapping them so that they spin out. Once you get them loose you can usually get them the rest of the way by hand. Then replace with a bolt of your choice that has the same length, width, and thread pitch. Done!
No festiva for me ATM...
IF you're talking about replacing only the switch and not the key tumbler IIRC the switch is held onto the tumbler by a single regular 'ol screw. It's kinda hidden amongst the wires.Originally posted by Ford Fester View PostAnyone ever replaced one. I bought a festiva that i am fixing up and the previous owner had afro engineered a new ignition switch into the cigarette lighter socket. Luckily they didn't splice any wires in so wiring is the easy part. What I am stuck on is the ignition switch itself looks to be riveted in place. Didn't know if they was a couple secret bolts that i dont know about. I will post some pictures....Thanks.
Remove the screw, unplug the harness, ( there are 3-4 separate plugs), remove the switch.
No need to remove the tumbler.
Hope this helps.Last edited by lessersivad; 01-04-2012, 05:19 PM.
