Pink/green/pink
P G P
IIRC, there is a write-up in these forums somewhere that tells you step-by-step how wire them to take standard blade fuses as well, using 1/4" female quick connectors, because we festivers do stuff cheap, and blade fuses cost a lot less than the modern encased fusible links.
Blade Fuse = $2.99 for 10
Fusible Link = $3.43 each
(At Advance Auto Parts)
Should be 20 30 20 really stock is 15 25 1593 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RJ
Handful of cartridges cost me $1.00 (the admission fee) at the pull a part. They never ring up the fuses if you're buying something else too. Even if they did ring them up I think they are... $0.23 a piece lol. A lot less work than rewiring. And it doesn't require getting standard fuse holders eitherOriginally posted by Cruiser627 View PostIIRC, there is a write-up in these forums somewhere that tells you step-by-step how wire them to take standard blade fuses as well, using 1/4" female quick connectors, because we festivers do stuff cheap, and blade fuses cost a lot less than the modern encased fusible links.
So you come out cheaper anyway
No festiva for me ATM...
Cruiser wrote:
"Perhaps, unfortuntely I haven't found a Festiva in a pnp around here in months."
You don't get the colored fuses from Festivas. I can't recall exactly which cars, but I think some newer Fords and maybe some Mazdas have them. Just look around and you'll find some. Just make sure they're the long leggedy ones.
