I'm sure it can get better, but the first mileage check was 32mpg. I changed plugs, cap, wires, coil and rotor yesterday so I hope it improves a little more after the tune up. Now just the wait for Summit to deliver my new intermediate pipe and muffler.
my first fuel mileage check
check the timing and tire pressure!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Also check your tire size. Stock sizing was 145/80-12 or 165/70-12, which are about the same diameter. If you're running 155/80-12s then you need to add a bit to your mileage since they will turn fewer rotations for the same distance, indicating you haven't gone quite as far.
On the other hand, folks report that stock sizes do not match what they get on their GPSs and that the 155/80-12s are actually a bit closer to real speed driven.
Best thing to do is to get your own GPS and check your real speed and distances to get a more accurate reading.
Oxygen Sensor and thermostat (how's your heater?) can effect it as well.-------------------------------------------------------------------------------------------
My Musica! Click me!
Originally posted by Movin View PostCorn free fuel helps number crunching..
Here on the east coast, non-contaminated gasoline is hard to come by!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Think you can still get real gas at marina's, but I haven't tried that route yet.
Likely boat fuel doesn't have road tax on it so, they wont let you fill the car up directly.
My dad has a '54 Hudson that he has finally come to understand that it doesn't like ethanol contaminated fuel. So 5 gallons at a time he get fuel from the marina. Fortunately, for everyone, my dad doesn't drive very much!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Movin View PostEthanol contaminated !! I like that!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241 View PostOr my favorite term for 10% ethanol gasoline, crapoline!91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
