Grooved roads, any others with problems?
  • Grooved roads, any others with problems?
    We went up to Indianapolis the other day, using the highway the whole way (we usually route through Beech Grove - a town right south of Indy), and noticed something they've been using recently.
    This: http://eplay.typepad.com/photos/unca...2pc3936p_3.jpg
    Whenever we hit it, we have almost zero traction. It's alright when you're slowing down, but when you have cars on either side of you, you're doing 65MPH, and drifting all over with no means to stop it, it's pretty bad. It's as if the tires are being airborne.
    We talked to someone who said a lot of motorcyclists will walk that stretch of road, because they don't have any traction.
    The tires are pretty new, but she does need an alignment. Any possible fixes on our end for such a problem? Or do we have to call our congressman?
    ~Spike
    White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
    1988 LX 5-speed
    ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
    Gone:
    If your going to call someone, the best person to call would be your local Department of Transportation office. (This is not the DMV) You will want to talk to one of the design or project engineers. A district engineer would be handy too. Tell them there is a dangerous part of the road that is causing your vehicle to have traction issues. These guys will take it more personally for the most part since they have to live with the road, the congressman doesn't. It could be an experimental thing they are trying. Even if it is not, they should value your feedback. I am engineer and deal with alot of highway projects. Our state does not install these cuts, so I am not familiar with their purpose, design, or intention.
    The Festiva Store
      Some roads like that are bad if not done correctly, but I would get the alignment done to your car. That is probably a big part of the problem.
      Alignment issues will cause a car to drift on smooth pavement, worse on grooved roads.
      Dan
        I don't think I've ever drove on pavement with the the grooves going across.
        I can see where it may cause traction problems with a less tire/pavement contact patch.
        I would say the reasoning is for drainage.
        Now, my experience with grooves going with the flow or direction of traffic is not pleasant.
        Complete 4 wheel alignment helped slightly but the Festy still wanders in the grooves. I have found that by steering diagonal (staying in my own lane using a subtle, slow weaving) I can drastically reduce the "jerking and tossing" caused by the grooves.
        BTW, I'm running 155-80/13 tires.
          While I was at work, my mom called both.
          EDIT to first post:
          Picture I meant to post was one going WITH the flow of traffic, not side to side. My mistake.
          I guess it's time to set up an alignment appointment. Figure I can get them to check my CE light while I'm in there.
          Lessersivad - That's what I'm running. I suppose I'll try weaving next time and hope it helps out.
          ~Spike
          1988 LX 5-speed
          Gone:
            We have them here , i have new tires and alignment and car drifts scary bad on those grooves . I think they are for icy conditions to provide traction .
              Tighter Align specs. closer to stock wheels.
              Tires that are more rounded.
              Lots more but start here..
                I had to remove my oversized front tires and put the 12s back on because they would follow any road inperfection.
                  Did it with my 12 inch stockers - did it with my 13's 40mm offset and 14's on both cars with new alignment good bushings tierods and new struts . I think its more about weight , and yea its scary on my motorcycle too . My friends geo does the same thing - i have to go about 55 in a 75 for it to handle comfortably .
                    Its the road, not your alignment. There is a stretch of road near by like that and it is scary to drive on. I was in a brand new VW and it was drifiting side to side alot on that stretch. I don't know why they are making roads like that, but it is a terrible design and is probably going to get people killed.
                    '90 LX
                      Kinda feels like mixing bias and radial tires but worse !
                        If it only feels that way on that type of pavement its the road. With my snow tires (175/70/13) it feels like I just keep getting nailed back and forth with huge gusts, but with my summer tires (195/50 and also with 205/50/15) its not noticeable. I think it has to do with the contact patch of the narrow tire trying to follies the grooves, thusly why motorcycles have a hard time, their contact patch can be less than an inch on some. So don't worry, its just the road. But you do need to get it aligned soon it will start to chew up those tires.
                        Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
                        Dennis
                        93 GL In progress BP/hydro G
                        15 Mitsubishi Mirage daily
                        88 Dakota tow pig
                          US-23 through southern MI is that way. 2006 Corolla on 205-65-15s and I was constantly sawing at the wheel. My first thought was "what about motorcyclists?"
