Hey all, just thought id share my experience with the oils i have used in my gtx, if i found a thread like this about 3 months ago, i would have saved TONNNS of cash experimenting with different oils to see what yielded the best results, so im sharing my experience for future g series/ gtx owners.
some back ground: the car itself only has 170,000 kms. for a 1987 thats not alot IMO, but from fast 1st to 2nd gear shifts and fast 3rd to 2nd gear shifts there is an infamous grind. The transmission is getting a complete overhaul this summer but for now this is my experience with the oils i used.
1)ATF (was in the car when bought).... Worst oil, grinded no matter what from 3rd to 2nd gear, and any shift from 1st to 2nd above 4000 rpm it grinded hard.
2)10w30 as per club protege (just as bad as ATF). Grinded from 3rd to 2nd unless going under 30kmph.. 1st to 2nd grind was bad to.
3)75-90 full synthetic amsoil baller yo.... Used this in my miata race car... 2nd best oil i put into my trans. 3rd to 2nd was ok under 50kmph.. 1st to 2nd grinded anything above 5000 rpm.
4) Syncromesh gear oil from GM, Id say same deal as the 10w30.. grinded from 3rd to 2nd unless going under 40kmph ish, 1st to 2nd grind at 5000 ish rpm
And lastly the best oil:
5) 80-90 ac delco (cheapest gear oil i could find).... AMAZING!!! completely transformed my transmission. no grinds from 1st to 2nd, 80 kmph downshift from 3rd to 2nd without a grind provided i did it slowly and with the clutch all the way down. Even cold the trans was ok, and im talking -30C
Moral of the story, 80-90 cheap gear oil yielded the best results, and it was the cheapest in my case!
