Yesterday I googled this subject. I had always been a bit leery of the thought of mounting the 195/45-14s on 5.5" wide Miata "Daisy" rims, and mounting the 175/50-13s on 4.5" Aspire rims. This guy agrees with me:
From his article:
"The ratio between the section width and the rim width is pretty important. If the rim width is too narrow, you pinch the tyre in and cause it to balloon more in cross-section. If the rim width is too wide, you run the risk of the tyre ripping away at high speed."
He provides the mathematical formula to figure this and also a calculator he made up so you can simply punch in the numbers.
And his calculator says that minimum wheel width should be 6.5" with the 195/45s and 5" with the 175/50s. I was planning on running the 195/45-14s on stock Miata 6" wide rims, and I have to say that seems safe enough, but it confirms my hesitation to do so on the Daisies.
Here is Yokohama's tire width chart page:
It only shows some of our tire and rim choices, but it seems to agree with the previous site.
So far I've not heard of anyone having any problems with the tire/rim matches I was cautious about, so maybe some folks overstate it. But I'd feel a lot better NOT running too wide a tire on a skinny rim. As you get into the lower profile, higher performance tires, be more careful.
A 175/70 on an Aspire rim (4.5") should be fine, but if you're running the ultra low profile 175/50s, just be aware.
Thoughts?
Any other sources of tire/rim width matching guides?
Remember, it's at the limit that any dangers would make themselves known.
Karl
From his article:
Thoughts?
Karl
