when my brother turns on the air conditioner it seams like the car wants to die because the idle is too low. is there a way to increase the idle on this motor?
the idle control valve is probably gummed up. They say it's not serviceable and you can't clean it, but I have cleaned 3 of them without problems.(it's bolted to the throttle body with 2 bolts, looks kinda like an electric motor). Just clean it out with some carb cleaner and blow it out with compressed air if you got it. Hope that helps.
it idles low when he only turns on the airconditioning and i was just trying to idle it up a bit and thank you for the relys...i am glad i got a netbook cheep
