I need help with connecting my power steering pressure switch to my electrical idle up switch. I have no ECU.
I unscrewed the electrical contact from the power steering pump to determine the principle of operation. There is a stiff spring holding down a tiny copper plunger with a small hole under it to allow the pressurized fluid to push it up to ground out the circuit.
OPERATION
The switch provides an input to the ECM during periods of high pump load and low engine RPM; such as during parking maneuvers.
My question is how would I wire the electrical connection without an ECU? The circuit grounds on high pressure (probably greater than 400 psi). My Toyota idle up switch works when power is supplied, a solenoid opens to allow manifold vacuum through an adjustable proportioning valve to relay vacuum to pull on the throttle. This idle up is used for A/C as well. When I turn on the air, it energizes the circuit.
I need something that allows current to flow to my idle up switch when the power steering pump pressure switch grounds out.
OPERATION
