Factory cruise control
  • Factory cruise control
    Just curious how many, if anyone, has a working factory cruise control in their festiva ??
    cruise control
    Good morning Fresh, RJ- skimsucka has cruise and mentioned that it worked good, he did have a B8 in the car at that time.
      Have a Ford Factory cruise control still in its box, just havent got around to installing it!
        I have a factory cruise that works and will be sent to sc72 shortly.
        Ford Fester
          I want cruise so bad!
          My Musica! Click me!
            Someone needs to come up with a plug n play custom cruise control setup for Festivas and Aspires.
            Just a thought.
              I second that.
              1963 Ford F-100
              1992 Ford Festiva
              2006 Audi A4
              2012 Kawasaki Ninja 250
                I have everything ready for a single throttle cable. I forget which car I saw it in the junkyard. It was an import. Honda? I should have removed it on the spot. Two cables in, one cable out. There is room for only one cable with my twin carb linkage. I have everything else but.
                  Originally posted by sc72 View Post
                  Good morning Fresh
                  Guess you finally ate some supper and got to bed last night ?
                    I have cruise control. It's a dealer installed unit I pulled from a Festiva in a junkyard.
                    ~Austin
                    Red 88 L (Ocho)
                      Factory cruise yes but in the 94 Aspire I had. Believe it's the same unit.
                      91 rusty Festiva 260k
                        Oren and Eric. How about some pictures so that we know what to look for at the JY. Also the control stalk.
                        Someone installed a fle bay one about a year or more ago. No, I didn't do a searech yet. Wondering how that worked out and if it is still running.
                        I hate being Bi-Polar, it's awesome.
                          I'll try to get some soon.
                          ~Austin
                          Red 88 L (Ocho)
                            I've got some of the cruise parts kickin around waiting. I'm wondering what difference there'll be when using a G-Series though.
                              i use to keep a brick on the accelerator cable
