egt bent valves...
  • #16
    also what specific things should i look for when i go look at it tomorrow?
    91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
    Adjustable VW MK2 front suspension and Aspire disc brakes
    Aspire rear axle and drum swapped with adjustable KYB rear suspension
    LOOKING FOR RUST FREE SHELL IN CALIFORNIA
    • #17
      Originally posted by Powerstiva View Post
      ok so i got some questions , first... if it isnt the BP will it still fit in a festiva? also if it is what is a reasonable price to pay for it? does 175 sound good? and when i pick it up form it guy (if i do) how sould i transport it? its just the engine, and i only gotta drive about an hour at the most with it.
      If it's the 1.9 CVH then no it won't fit. I have loaded 1.6 DOHC engines into the back of a Festiva before, they do fit. 175 sounds way high for me, if it is "damaged" like he says if you look on www.car-part.com you will see good used BP's listed fairly regularly for $150
      1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
      Rocketchips!
      Bolt-on Weber Carb Adapters!
      • #18
        The ad says the motor was from a 91' so it "should" be a BP and I've broke a timing belt on a BP and didn't hurt the valves at all, put on a new and was good to go
        • #19
          Ok thanks for the help!
          • #20
            The fact that he says it's 91 AND notes that it's a Mazda engine makes me think it's probably a BP. Do a quick google search for BP motors, then one for cvh motors. After looking at a couple pics of each you will be able tell pretty easily which one it is when you seeit. for what it's worth I bet the valves are fine, my guess is they just didn't ow how to get the new timing belt lined up right.
            No festiva for me ATM...
            • #21
              I just purcesed it, it is indeed a BP. When he pulled it out he said it wasnt running, and it was cuz of the timing belt, however i believe it may of been as htchbck said with the belt. I will be starting my own build thread and see where things go.
              • #22
                Did you at least get him to lower the price at all?
                • #23
                  no i wasnt able too =/ i did get a starter motor too... but im mising the wiring harness for the engine =(
                  • #24
                    Just modify the stock harness for the BP, it's easy to do if you have a 90-93 festiva
                    • #25
                      Ok i will do my best, here is the link to the thread i just started http://www.fordfestiva.com/forums/sh...858#post526858
