SOHC B8 gasket set question.
  • SOHC B8 gasket set question.
    I have an engine out of a 1992 Mazda Protege DX (SOHC 1.8L B8 ) awaiting install with lots of help from gauge_half_inch. I'm set to the task of buying the odds and ends of getting it ready.
    When Link5186 and and him were removing it in the 'yard, he noted it had a small nose oil pump (I pray I'm right here, I'm very new to working on cars), and I believe he said he thought the B8 usually had a large nose.
    Anyway, my question is if this is the correct gasket set? I've done a lot of searching and haven't found any reference to large nose/small nose being a problem when getting a fresh set.
    Rockauto: http://www.rockauto.com/catalog/moreinfo.php?pk=1808722
    And the order page: http://www.rockauto.com/catalog/rafr...artnum=FGS4051
    Or if there are any eBay kits that would be more cost-effective and be the same thing? I've seen a few on there, but I really wasn't sure.
    Thank you!
    ~Spike
    White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
    1988 LX 5-speed
    ​​​1993 L 5-speed B8, E series, Aspire/Rio swapped
    Gone:
    Like this eBay kit:
    Fits Mazda Progete 1.8L 16V SOHC New Full Gasket Set BPE Replace OE Part #: HS9718PT, CS9696-1. This full gasket set is just what you need to keep your car in good running order. These full gasket sets are designed for the professional installer.
    ~Spike
    1988 LX 5-speed
    Gone:
      The difference if there is will be by year. The only difference will be the crank seal, that's all.
      Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
      Dennis
      93 GL In progress BP/hydro G
      15 Mitsubishi Mirage daily
      88 Dakota tow pig
        ^what he said. maybe a $10 seal, don't get it wrong or else.........
        1991 blue L, 5 speed.
        1988 red L-plus-all stock.
          Okey-dokey.
          ~Spike
          1988 LX 5-speed
          Gone:
